Best place to buy Rings/Main and Rod Bearings???
Right now I'm in the process of rebuilding an ej251 that had a rod knock due to a bad rod bearing.
Now that the block is split and everything is out, I figured I might as well go all out and re-hone the cylinders, replace the piston rings and obviously all the rod and main bearings as well as a few seals and such etc.
Where is the best place to buy this stuff?
On subaruparts.com, rings, rod + main bearings and main seal come out to be 353 bucks before shipping (a bit more than I expected).
I found some acl oem size main and rod bearings for about 40 bucks and I'm curious if those would work as well? would save me a ton of cash.
thanks in advance
thanks in advance
You should really get all your measurements before buying bearings, especially if there was rod knock.
It's worth the time (and cost of a micrometer set) for an engine that's properly blueprinted and assembled.
As for places to buy bearings, anyplace online works if you are positive of the application. I recommend finding a local shop that has an account with ACL to place an order once you know the size for sure.
Chibby Goku
05-08-2004 11:52 AM
