98 2.5 RS headgasket Q.
Car Info: 1998 Subaru Impreza 2.5 RS Coupe
I recently bought a 98 2.5 rs in June of 03. I was just wondering at about how many miles do the headgaskets start to go bad? And why do they go bad anyway? Thanks everybody
Run a coolant pressure test. You will notice that the coolant overflow bottle will fillup from system and oil can also appear in the overflow bottle. 3 layer headgasket problem is a known design defect. It was solved by a 4 layer design that solves the problem. File a case number with Subaru of America and take to a dealer to confirm and replace under known defect warranty.
WWW.rallitek.com is an expert shop and can assist in your problem.
Babu
Babu
Thanks for replying. Is there a way to know that my car hat it replaced? Because since I got it used, I don't know if the warranty was done to my car to fix the gasket. Thanks.
witchywen
17
10-10-2006 04:29 PM
dugrant153
02-27-2004 10:45 AM
