USDM EJ25 Firing order
Origami posted by dunnojack
Does anyone know what is the firing order of the USDM sti motor? is it possible to change that order if a different header is installed?
I don't think it is possible to change the firing order unless a custom crankshaft is ground. The crankshaft throws are ground to position the pistons at top dead center in the firing order. The ECU must also be modified or a standalone system must be used. The factory selected the firing order for optimum balancing and minimum harmonics.
gtfaded
03-18-2007 01:29 AM
EJ_20
07-22-2006 01:23 AM
keirnna
02-05-2005 02:38 AM
dunnojack
05-28-2004 02:29 AM
