uppipe question
Old 11-11-2005 | 02:47 AM
BlackSheep808's Avatar
Car Info: STi
uppipe question
hi i heard a lot of people telling me that sti's dont need uppipes because the stock is already straight.....my question is i have a gt-spec uppipe and want to know if i should go through the trouble in putting it in or just selling it
Old 11-11-2005 | 06:08 AM
Wingless Wonder's Avatar
Many WRX owners replace the factory uppipe because it contains a pre-catalyst for cold-start emissions. Over time, the catalytic converter can disintegrate, causing damage to the turbo. It is also restrictive to exhaust flow.
The STi does not use a pre-cat in the factory uppipe and therefore flows much better than the WRX uppipe. Replacing it with an aftermarket uppipe would not yield much benefit unless you have some sort of special application.
Old 11-11-2005 | 10:21 AM
depdivr's Avatar
Car Info: 2005 Black WRX STI
just curious... whats the special application?
Old 11-11-2005 | 01:31 PM
Origami posted by depdivr
Big aftermarket turbos which don't bolt to the factory uppipe or downpipe. There is a fair selection of bolt-on turbos for the WRX and STi but for race applications or built engines, those turbos can be marginal for all-out performance.
Old 11-11-2005 | 07:33 PM
depdivr's Avatar
gotcha, thanks!
Old 11-11-2005 | 10:15 PM
A bit off-topic, but here's one example of a Garrett GT30R turbo kit from Gruppe-S. There's a pic showing the custom uppipe with external wastegate flange for this turbo.
Old 12-06-2005 | 11:45 AM
Alpha's Avatar
Car Info: RSX Type S
Does this apply to the 06 WRX?
Old 12-06-2005 | 02:34 PM
'06 WRX does not have a pre-cat in the uppipe. Money is better spent somewhere else.
VitaminWRX
09-08-2006 10:03 AM
downshift
02-16-2004 01:41 AM
downshift
02-10-2004 04:19 PM
huck
12-02-2003 11:53 PM
V8haha
06-26-2003 01:53 PM
