Turbo Spooling sound...
Car Info: 2006 Impreza WRX Sti/Hawkeye
Okay. I hooked up a Hallman Boost Controller but I set it to stock. The thing that it spools up ALLOTT quicker then stock but when it does spool up to full boost at low RPM it sounds like either the BPV can't take all that boost. Makes a sound like spooling up but it sounds kinda like air leaks or something...
Another possibility that is unlikely but possible. In my car, under high load, i was getting an uppipe to turbo exhaust leak. It was very small and only under high exhaust pressure and sounds like a whistle. Dealer eventually found and fixed it
Car Info: '05 sti
same thing happened to me when i got a stage2 from FLI
not that they did a bad tune or anything, but i had a boost leak when they tuned it, and i fixed it later... so something about the HWG map from COBB fixed it
1) try slipping the gas pedal down to the matt (slowly getting it to like 12-15 lbs then stabbing it..
2) then just try matting it from 2400 rpms in 5th
when i just matted it from 2400 in 5th it kinda bogged for a sec... then hit about 21lbs for a sec then tapered quickly (5800 rpm) to 16 then held at 17(till red line)...
then i got the HWG map and it just went to 17lbs and held...
hope this helps..
hope this helps..
wrecks43
02-01-2007 10:05 AM
Hurucan
08-28-2006 12:15 AM
SubyWRXdude
05-08-2005 03:30 PM
rustokman
23
09-05-2004 10:35 AM
Silverbullet04
13
01-15-2004 06:45 PM
