Tial MS-V EWG reroute
Old 12-27-2008 | 05:29 PM
kmurphy's Avatar
Car Info: 06 obp sti
Here are some pics of the new tial ms-v wastegate which is essentially a 38mm with v-bands compared to a 44mm wastegate. This new wastegate is tiny Also some teaser shots of some notched tubing and welds. This will be going on a ewg uppipe that will be rerouted back into a cobb downpipe. Would of finished it today but realized my box of what I though was 1.5" flex bellows is actually 1.75" flex's so need to order some more before I can do final welding/assembly.
The new wastegate uses larger inlet tubing 1.75" compared to 1.5". Also is over 1" shorter in height compared to the older 38mm.
Old 12-28-2008 | 12:50 AM
PikkaGTR's Avatar
wow
so clean
maybe I should consider an EWG along with my meth setup
Old 12-28-2008 | 01:30 PM
kmurphy's Avatar
Old 01-12-2009 | 11:34 PM
kmurphy's Avatar
bump for new camera thanks to the g/f and light box pics....
Old 01-21-2009 | 06:55 PM
kmurphy's Avatar
Finally got this finished. Got the flex bellows finally this afternoon and immediatly started working on it. I just have one more weld to do on the flex bellow and its all done. I use gaskets to stimulate everything fully bolted. Tial 38mm v-band wastegate, hks uppipe, cobb dp.
Old 01-21-2009 | 07:50 PM
medicSTi's Avatar
Car Info: 2017 CWP WRX & 2007 SWP WRX
Great job, that is seriously some quality work. I'm considering EWG on my 08... it's sooooo tempting!
Old 01-22-2009 | 11:55 PM
kmurphy's Avatar
Thanks Hopefully he likes it.
mystilexzero
05-05-2017 03:35 PM
soccer05
10-24-2013 09:51 AM
jung187
11-25-2012 06:59 PM
verc
03-15-2011 07:26 PM
gesundlich
03-17-2009 02:40 PM
Quick Reply: Tial MS-V EWG reroute
