Sti real crank HP ?
Old 02-22-2004 | 03:43 PM
From the factory 300 is pretty accurate. Subaru hp fluctuates with the state of ecu learning however. Anywhere from 290-315 is possible.
Old 02-26-2004 | 02:33 PM
insaneSTi's Avatar
Car Info: Blue STi +Red del Sol VTEC
The thing that i laugh about most is when everyone says the turbo will only make 370 t0 400 at the crank and the injectors.
Think about this i dynoed my car at xxtuning and it hit 261hp and 270lbft. With a 25% drivetrain loss your looking at 350hp. Shiv's dyno shows 218 at the wheels and he even says his dyno is low since it's a load type dyno has lower #'s. Their baseline for the evo is 185hp.
Explain to me how a 3200lb car with 220whp runs a 13.0 or high 12 stock. Don't say the awd launch yes that helps quite a bit but where's the 105mph trap come from.How does another 3200lb car do mid to low 13's with 185whp and trap over 100. Easy it doesn't happen the sti's has about 350hp stock and the evo's like 310-320.
When i get my vishnu stage 1 i'm going to dyno it and i'm expecting about 310whp 325wtrq on the 93 map and 330whp 360wtrq so i don't know how 370 at the crank is the limit will make sense.
Also the stage 1 STi will run high 11.75-12.2@115-120mph and the evo will do 12.1-12.4@110-115mph. All this with 280whp and 250whp respectively. It just don't make sense when a viper has 500hp weighs the same and traps 120-125mph. The STi and Evo must have the most flexible motors on earth for that to happen.
Old 02-26-2004 | 03:43 PM
dashiet's Avatar
so the sti has 350 crank hp now? and the evo has 320?
and the stage 1 sti will run 11.75-12.2? wow, id like to see that. im not saying its not possible, but the figures seem to be a little farfetched
-dashiet
Old 03-21-2004 | 04:54 AM
TRM's Avatar
TRM
i was searching for dyno plots on some of the other forums...here's what turned up:
dyno plots @ velozt.com
04silverWRXSTI
Hawaii Classifieds
10-26-2007 10:33 PM
outlaw23
Hawaii Classifieds
16
10-30-2004 08:57 PM
Chibby Goku
12-27-2003 10:53 PM
Imprezer
11-20-2003 05:02 AM
Quick Reply: Sti real crank HP ?
