STI internals
Old 03-23-2006 | 08:19 AM
evsoul's Avatar
Car Info: 2005 Unicorn
STI internals
Hey does the STI have stronger internals than the wrx? (i would think so) just trying to clarify this.
i would think the rods and what not were designed a bit more heavy duty than the wrx, but i am not 100%
if the STI has stronger internals, what about them is stronger?
-greg
Old 03-23-2006 | 09:10 AM
mattsn0w's Avatar
IIRC, the USDM and JDM internals are both forged, where the WRX are cast?
Krinkov, Moike, one of you guys want to chime in?
Old 03-23-2006 | 09:16 AM
evsoul's Avatar
do you know if the 2006 2.5L wrx is essentially the same internals as the previous years wrx? meaning non-forged.. same materials.
thanks
Old 03-23-2006 | 10:09 AM
swift2fly's Avatar
Car Info: My Car
i don't think the USDM 2.5L STI is forged at all. altho i'm hearing that the rods are forged only. if the USDM STI's internals were forged i would think that, when pushing over 400AWHP, wouldn't be a concern on reliability.
Old 03-23-2006 | 01:50 PM
Krinkov's Avatar
forged rods and cranck, Hypereutectic pistons. Hypereutectic pistons work excellent when used at the stress levels they were designed for, but when pushed harder they dont provide the det resistance of forged pistons. Though I was pushing upwards of 340whp on Gruppe-s dyno with my GT30 for 40K+ miles on a stock bottom end with no problems at all so take that fwiw
Old 03-24-2006 | 01:35 AM
turtle-speed's Avatar
Car Info: 2004sti
Was your boost level around 18-19 psi ? Any detonation ?
Old 03-24-2006 | 02:50 AM
Krinkov's Avatar
yeah on 91oct mike had me tuned at 18.5psi, no det and I run a knock-link too so I would see it. Now that its back to stock with the old pre-reflash stock map my knock link goes off all the time!
Old 03-24-2006 | 04:29 PM
Car Info: 2004sti
Thanks for the response . I'm thinking of adding a knock-link to gt-30r set-up , to catch detonation running at 19 psi . Thought about a smc alcohol system but , decided not to go with it too much to worry about .
thunder_sti
04-20-2006 11:58 AM
VMI06WRX04
Wanted
11-15-2005 06:24 PM
thunder_sti
09-30-2005 04:18 PM
Quick Reply: STI internals
