Sti intake intercooler maf sensor install problems
Hey I have a 06 Sti and I just installed the Perrin fmic kit with the red perrin short ram intake using stock bov because I haven't gotten a flange for my greddy rz bov. Okay so I got everything hooked up using the stock maf sensor on the Perrin short ram intake. My intake cone the sponge filter came drenched in oil I read on perrins site that they spray it with oil to keep dirt off. So my first pull from first to second gear I hear a pop and the car shut off it would start and shut right off it would barely move so I plug out the maf sensor and the runs but not fast at all and when I plug the sensor back in while the car is running it shuts off. so I cleaned the sensor that didn't work now I want to know what I should do. Should I wash the cone part of the intake with water does the oil necessarily have to be in there? And should I buy a new stock maf sensor from denso? Or will any cheap eBay maf sensor work?
Nobody likes the tuna here
Wash the filter and lightly oil it. Too much will dirty your maf. Clean the sensor with maf cleaner and a q-tip. If that doesn't work. And it's the sensor faulting out. The eBay ones will not be a good choice get an oem one. Also check to see if you have any leaks anywhere and also all your vacuum lines are intact. You might have popped something on your first spin.
anthonys192
11-03-2013 09:24 PM
tscott915
Wanted
10-01-2009 07:46 AM
dan avoN7
12-19-2006 10:46 AM
grex767
05-27-2006 11:37 AM
