protune Stage 1
Car Info: 07 Silver Mazdaspeed 3
Any map can benefit from a protune...... BUt if power is you ultimate goal You should probably wait and only have to do it once rather than get re tuned once you add new mods.
Originally Posted by lburrrna
06 wrx tr, running on stage 1 ca-maps. should protune stage 1 (is it worth it?) or i just wait for stage 2 to get it protune?
I would get a pro-tune after Stage 2. You should look into the Perrin crank pulley like I got. It's like reducing 100 pounds of weight from your car.
Originally Posted by wu!
I have an '06 WRX as well on the same map. I wouldn't bother pro-tuning Stage 1.
I second this... and it isnt underdriven, hence not F-ing with anything in the engine, def a worhtwhile mod... while youre at it, you might wanna replace your intercooler hoses... Perrin makes a great set
I'm also waiting to see how well the SPT high-flow air intakes perform.
sabrebluewhale
07-20-2008 07:53 PM
06blackwrxtr
35
01-12-2008 01:16 PM
lburrrna
19
11-23-2006 11:58 AM
