oil (consumption) problem?
Old 06-04-2004 | 04:50 PM
jcorrao's Avatar
I don't think it's normal for ANY car to burn that much oil. That sounds ridiculous. IMHO!!
Old 06-04-2004 | 05:49 PM
shark-bait's Avatar
i usually have to add a quart between changes too. ive heard of other people with the same problem, dunno either if its a problem problem, or a normal thing, but at least it happens to other people
Old 06-04-2004 | 06:50 PM
MidNite Runner's Avatar
Car Info: 2002 RS
did they add oil to the filter before they installed the new one. you don't have to but if you don't you will run short a little oil and need to add some. Therefore if they didn't add oil to the filter some of it is now sitting in the filter.
Old 06-04-2004 | 08:23 PM
jcorrao's Avatar
the technician I spoke to about oil consumption stated that, "it is normal to burn maybe a quart b/w oil changes within the first few thousand miles", but that it should really slow down after that. 1.5 qts is a lot of oil for an engine to consume.
Old 06-04-2004 | 10:00 PM
wrexr's Avatar
Car Info: E28M5, RAM Powerwagon, Motos
My STi used 1 quart every 3k miles for a while. It would also use a quart every track day until recently. I have started running it a lot harder and feel like the engine is the strongest it has ever run. It has not used/burned oil now for the last two oil changes and track days. The car now has 15k miles on it and the oil has been changed 6 times. It appears to me that it took 10k + for the engine to fully break in. I also have experienced better mileage over this time as well.
-Good luck
Edit: I use redline synthetic oil btw.
Old 06-05-2004 | 05:57 AM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
i have the same "problem" even with synthetic oil.
however the only real problem i have is that oil is expensive
Old 06-06-2004 | 11:13 PM
kool168's Avatar
may be your engine not break in properly? the piston rings didn't seal well and it burns oil?
too early switch to synthetic oil will cause burning oil as well...
Old 06-08-2004 | 03:56 AM
gdogg's Avatar
^^^ thats a scary thought
Old 06-15-2004 | 01:31 AM
Group B's Avatar
Dahveed aka Robin Hood
my wrx used between 1-1.5qts between changes, and so does my STi, which is at 7k miles.
I drove my WRX hard, and I drive my STi hard as well.
I will switch to REDLINE 15W-50 at my next change, and will switch to REDLINE 10W40 for the winter months.
