Might change turbo to VF34, would i notice a difference in power?
Car Info: 71 rb26 240z
I was doing some research on buying my mods for my STI, and i kinda thought of instead of paying all that money to buy a full turboback w/o cats and header, why dont i buy a new turbo instead. I just wanted an idea if i did change the turbo.
Now, if you have the P18 housing, you essentially already have a VF34, just with a slightly more efficient compressor wheel. It's really not worth putting a VF34 on your car unless you're getting boost creep. If it were me, I'd put a VF22 on the car at the very least if you're interested in making more power. Your stock fuel system can keep up with it.
i say save the money and dont be in a hurry, i think that once u pu that vf34 on you prob gonna replace it in the future, the stock turbo has potental, i was puting down 310@ the wheels wit the stock turbo@ only 18lbs
I agree and if you port the vf34 and are using EM ECKUTEK you are going to be in for trouble believe it. keep the 39 on do the EM upgrade and at least the CB exhaust you will be happy for a while. You will them want to do a turbo and injector upgrade 20g or green etc.
Car Info: the blue bucket
If you think the stock 480cc ish injectors on the USDM STI are capable of keeping up with a correctly tuned VF22 you are gravely mistaken. The stock fuel system see's IDC's above 90% on a ported VF39 running at no more than 17-18psi using a Walbro drop in as well. Admittedly these cars also have full catless systems (headers to) and put down about 270whp and 290ftlbs.
Mike
Mike
Mike
Originally Posted by BAN SUVS
What's wrong with the VF34 and Ecutek combo?
Its a difficult tune one that most don't know how to do. Trust me you will not be able to make any boost if you P&P a vf34 with Ecutek it has something to do with the pill size and if that doesn't work you will have to run a boost controller. Only Ecutek has this problem. It cost me alot of money coming up with nothing so I put back on my VF39. I'm running the following: Ecutek, walbro , Injen FMIC, CAI and C/B exhaust. The car runs great. If I were to upgrade it would be a 20g and injectors re tune Ecutek.
I would suspect either the port job was a little over zealous causing you to not make/maintain boost or the tune/tuner was off.
Mike
Originally Posted by UK n00b
I would speak to whoever did the tune for you then as your statement above could not be further from the truth, there is no difference tuning a ported and polished VF34 with EcuTek than tuning a VF39 ported or otherwise with EcuTek, sure some of the maps need changing but they do with any tune such it's sometimes called mapping
Mike
Mike
All I have to say to you is have you done it, I would say by your statement that you haven't. I have and the tunner was Ben Dagenais of Ecutek he did the tuning and the Vf34 was P&P by deadbolt please don't be like other people and talk about something you heard and not what you did. If you do a search on the Nasioc technical section you will know what I already know.
Your new here so I guess you dont know who your trying to flame, but Mike is the in house dyno tuner for Gruppe-s and has more experience making power out of Subys with every combination of turbos and mods than 99.9% of the other talking heads on this forum. So um, yes he does know a bit more about what hes talking about than you or I and does not pass on any info that he has heard and not experienced.
And as for searching NASIOC, you might just run across my post in the 2.5 forum where I put down 276whp/307wtq on a tuned P+Pd VF34, and Matt (Still Will) put down 279whp/323wtq on a tuned P+Pd VF34. So yes, you can make a bit of power with a properly tuned P+Pd VF34
cheers
Umm, dealing with this is common knowledge. I used to work for vishnu Performance Systems, and part of shipping a VF34 OR reflash package is ensuring that the customer gets the proper restrictor pill and/or bleeder. Whoever installed your turbo didn't know what he was doing since he obviously didn't get the vacuum lines correct.
Originally Posted by Krinkov
hoo boy,
cheers
cheers
