Make your own COLD AIR INTAKE for 7 Dollars
You should try putting some kind of funnel where the tube comes out the front of the car. It might be easier for air to enter the pipe when driving at higher speeds due to all the turbulence. My 2 cents.
Funnel......
It's called a..... BELLMOUTH & we also covered the front with mesh to stop
stones & small critters from making a new home!!!!
Car Info: 03 Evo, 88 RX-7 T2
Hacka Duct
My version I did a while ago. I originally posted it in "Ongoing Projects".
Notice the same silver dryer vent inside.
https://www.i-club.com/forums/showpo...0&postcount=74
That was gonna get changed to the black brake ducting, but the front bumper was jacked in a recent crash. I am replacing the covers with WRX foglight surrounds for a cleaner look for the ducting.
And yes, it reduced intake surface temps by 50 degrees.
-Kevin
-Kevin
Intake
Originally Posted by 500whp.com
is that just any kinda screen? How did make it stay?
tie it around the intake... IT WOULD BE IN THE GARDEN SECTION. TRY FLY SCREEN
BUT NOT THE METAL MESH!!! SOFT CLOTH MESH
Originally Posted by kidatari
This thread makes my head hurt. Yes, let's put zipties and aluminum dryer ducting in our airboxes!
PUT IT IN THE FRIDGE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Thanks for the idea...
Just did my cold air infusion...
Here is a link to what I did today...some pics.
Just added the finalized pics where everything is painted and clear coated...scroll down to the bottom...
https://www.i-club.com/forums/hawaii-43/cold-air-infusion-101509/
Not to pee on your pomegranites, but i've got a couple reasons not to do this.
1 hydro lock is only a matter of time
2 you're turning a cai into a cai
3 on many cars, that's a low pressure area
4 flexible tubing creates a lot of turbulence
5 the intake is pulse-tuned (granted this isn't that important to a turbo car)
If it works though, run with it.
Have you tried it w/o the duct and just into the fender (block off the fender to wheel well holes except the airbox one) I'm not sure the air outside by the bumper is any colder than the air in the fender. I've done measurements of just the fender area and that's plenty cold.
The material you used (drier duct) will eventually start to shread due to the vibration. That's what happened to others that have used that material. Here is some temp work I did in the past:
http://www.scoobymods.com/forums/showthread.php?t=164
http://www.scoobymods.com/forums/showthread.php?t=4281
You should get the same results just doing this:
http://www.scoobymods.com/forums/showthread.php?t=4475
I don't have any pics but I did this to my WRX. I had the silencer deleted already w/ a black plastic elbow into the fenderwell... in this hot summer weather I saw IAT's climb into the 120's and 130's.
I'm honestly not concerned about water or pulse tuning... I have a filter to block dirt and water... not to mention the water would have to go a long ways. I suppose if I totally submerged the front of the car something could possible happen... but then again it's not really air tight where I put the tubing into the elbow.
It looks kind of ghetto being silver.. but w/ a WRX fog light panel w/o the fog light it fits pretty darn well.
Anyway... 120+ intake temps down to maybe ambient +5 is a huge difference. Fenderwell air in the Rex must get pretty heated up by the engine bay.
For those people who have a fenderwell draw I'd take a look at your IAT's.. you might be surpised.
Anyway.. final comments... took almost no time to do, cheap, and effective.
