intake for sti
Old 09-21-2003, 06:28 PM
cann's Avatar
get regular one
CAI will get u a lot of weird engine noise, and u can't clean the filter easily
cann is offline
Old 09-24-2003, 07:27 PM
awns729's Avatar
Car Info: want a WRX
CAIs dont really matter with turbos and intercoolers
awns729 is offline
Old 09-26-2003, 12:55 PM
Dahveed aka Robin Hood
Group B's Avatar
With FMIC:
Flip your intake manifold, delete A/C compressor, and run much shorter piping...
Group B is offline
Old 09-27-2003, 09:43 PM
Group B's Avatar
not cheap, and I don't know who makes the piping
Originally posted by metoo
Great idea! Should only cost about 20 bucks and 30 minutes of your time.
Group B is offline
Old 09-28-2003, 10:31 AM
Silky's Avatar
Car Info: 06 Evo MR
http://www.kaynzengineering.com/stealth.htm
The longest part about getting to this air filter and cleaning it is.. jacking up the car. Otherwise it will take you 5 minutes max.
Silky is offline
Old 10-11-2003, 11:38 PM
Krinkov's Avatar
Heres what I did about a CAI, works great
I was going to get an AEM CAI butafter hearing all the problems with using a CAI, I figured I would just get one of the Ebay reverse engineered CAIs, if it didnt work out, Im only out 35 bucks. I hook it up and it does just what everyone says it will, good down low, but by fourth gear I can only make 9psi, by 6th im making 4 I go to put to stock box back on and notice the the hole with the rubber gasket in the stock box that goes down to the snorkel actually fits and makes a perfect seal over the secondary CAI pipe, the one that goes sown into the fender well! so I install the stock box back with the CAI pipe feeding into it and just cut out the paper element, works like a charm! I get better bottom end and response and no problems with boost, best of all it looks completely stock
Krinkov is offline
Old 10-14-2003, 08:58 PM
Originally posted by tm999xxx
umm...cold air into hot turbo...just get a short ram
Ram airs are bad. How is using hotter air than the factory intake gets possibly better? "Cold Air" intakes aren't really any better. The best case scenario for an aftermarket intake is that it works exactly the same as stock. If it flows more than stock, your MAF readings will be off, and the car will run lean. If it reduces flow, which some intakes do, the car runs rich. The worst part is that intakes have different effects at different loads and different RPMs.
As for sound, if you remove the silencer and plug the holes in the fender, it will be just as loud as an aftermarket intake, only cheaper and safer.
Kevin M is offline
Old 10-14-2003, 09:03 PM
Silky's Avatar
Car Info: 06 Evo MR
cold air is better because it's dense... more air = more power. Even if that greater quantity of air is going to be immediately heated up it's still there and in greater quantity... = more power
and besides the intake side of the turbo is hot... but not as hot as the exhaust side so cold air does matter before it hits the intercooler.
Unless I just have that totally wrong. In which case I want pictures!!!
Silky is offline
Quick Reply: intake for sti
