ihi vf34 turbo question (do I need STi 'pinks' for an '06 WRX?)
Old 10-26-2006 | 06:58 PM
Subie do's Avatar
Thumbs up
Originally Posted by Mr. Furley
I got a vf39 for $300.... got me to a 12.90 1/4 with a stock intercooler.... ALL YOU NEED is the turbo, gaskets, accessport, exhaust, and a bigger intercooler. You DO NOT NEED injectors or a fuel pump.
I concur.
Nice job with the 12.9!
Old 10-27-2006 | 11:43 AM
rallied out wrx's Avatar
Car Info: 06 WRX, 04 FXT, 02 Forester L, 95 JDM LGT
now that we know theres no need for injectors upgrade.... is there a need for upgraded fuel pump of is the 06 also have a better than previous years pump??
Old 10-27-2006 | 11:44 AM
never mind answered my own question.
Old 11-23-2006 | 02:07 AM
wrXtian's Avatar
Car Info: 06 wrx
can the fuel pump support a 16g?
Old 11-23-2006 | 12:25 PM
Superglue WRX's Avatar
Bigger injectors typically require a higher flowing fuel pump. If you're running stock injectors, then the stock fuel pump will suffice.
So the next question would be, can you run a 16G (or "BIG" 16G) on the stock '06 injectors?
Old 11-23-2006 | 12:51 PM
Krinkov's Avatar
I know people running 20Gs (barely) on pinks, so I think you'll have plenty enough room for any of the 16gs
Old 11-23-2006 | 01:55 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
I would highly recommend upgrading your fuel pump. The OEM pumps are very inconsistant once you start pushing them and about 20-30% of them run out of fuel with any sort of turbo upgrade.
As far as the guys saying you should get a bigger turbo, I'd suggest taking that with a grain of salt. The VF series turbos are great on the 2.5 if you're after amazing response and good overall power. The 18g and 20g give just a bit more top end power but they really reduce response significantly... for my personal uses, the trade-off is just not worth it. The vf34 is a great turbo choice for a great ballance of power and response.
Old 11-27-2006 | 07:25 PM
SuperHawk's Avatar
Car Info: 2006 WRB Wagon Ltd.
Hey Ed,
Would the Big 16G be a good upgrade for the 2.5 with maybe just a little more headroom above a VF34? I have a stock 06 wrx and am coming from a Stg 4 02 WRX with a VF30 and want just a little more power than that set up. I live in Cali and my car will never see meth injection or race gas. So my future upgrade path will most likely look like this--- Cobb AP, turboXS stealth back, prodrive axleback, fuel pump, larger top mount intercooler and different turbo.
I live in Vacaville so you will more than likely be seeing me in the future.
Would change any of the above mentioned items?? My car is also a wagon and that is the reason for my exhaust choice, I might even go with a STI axle back.
Thanks Dennis
Good Luck with the new shop!!
Old 12-01-2006 | 07:02 AM
Uncle Scotty's Avatar
The stock pump on the '06 is a <145L/hr pump(the pre-'06 was 130L/hr) but I would still upgrade the stock pump for any non-vfxx turbo.....and IMHO, an 8cm 18g or 8cm FP Green is the better choice for a 2.5 street turbo
Old 12-01-2006 | 03:13 PM
SuperHawk's Avatar
Just one more question. If I went with the 8cm 18G would you do it with a TD05 or TD06 configuration?? It seems like the TD05 config is the more widely available and would spool faster making it a better street turbo.
Super
Old 12-01-2006 | 06:17 PM
Super
td05....no doubt
gruppe-s
Engine and Drivetrain
12-12-2006 07:20 PM
gruppe-s
09-22-2006 07:34 PM
lovesmysuby04
SoCal Classifieds
08-16-2006 05:26 PM
sLeak
13
10-26-2005 03:51 PM
PogiMarky
10-20-2003 01:36 AM
Top
