ihi vf34 turbo question (do I need STi 'pinks' for an '06 WRX?)
You will need the STi pink injectors, Walbro fuel pump and engine managment, such as Accessport, I also would recommend a protune. Gruppe-S.com is selling VF34 turbo packages for pretty cheap.
1.) Disregard the above posts, they either misread your question, or just don't know any better. The 06 injectors flow MORE than the JDM STI "Pinks".
2.) You are to read this link and continue to research how to modify the 2006-07 model WRXs
http://forums.nasioc.com/forums/show...light=06+pinks
Originally Posted by fenderstrat066
ok first off i never said get pinks, and second of all stock EJ205 wrx injectors cannot handle a vf34... but EJ255 injectors on the 2006 WRX provide plenty of flow for a VF34
i know about everythign else i just need to know how much the tuning is going to cost, and will i be able to drive to the place if i install like the turbo and everything else dont feel like typing it??/
Ask around for good shops in the socal forum. Those peeps should be able to point you in the right direction.
Originally Posted by 1sicwrx
My bad, I was under the impression he was driving a 02-05 WRX.
I got your back
i will say the vf34 isnt a very good turbo in my opinion. The Mitsubishi turbo's 16g, 20g...have better flow rate and if you order from Deadbolt they give you free rebuilds for life! A vf34 is not too small for a 2.5L wrx though, the STI has a vf39 which is even smaller...It really depends what your looking for. If you want lots of low-mid range power get a 16g, 18g for more mid-top end, and a 20g is an awsome highway puller.
for everyone here who hasnt heard, the 06+ wrx uses 560cc top feed "Blue" injectors
https://www.subarugenuineparts.com/p...oducts_id=1066
lucky bastids
and yeah, unless you can get a sweet deal on a used VF34, I would take a 16G over one for the price
http://linux.forcedperformance.net/m...egory_Code=WRX
lucky bastids
I got a vf39 for $300.... got me to a 12.90 1/4 with a stock intercooler.... ALL YOU NEED is the turbo, gaskets, accessport, exhaust, and a bigger intercooler. You DO NOT NEED injectors or a fuel pump.
