i want to hit low 11's or high 10's....what's the smallest turbo i can get?
banned
Car Info: WRX STi 2004
So my goals are to hit low 11's or even high 10's on my 04 STi.... I am trying to figure what the best turbo set up i should use...i need help!!!
Car Info: 05 STi
I've seen 400 whp hit an 11.2 but again, that's dyno speculative. He was running a GT35 which is much bigger than the two I mentioned. The FP Red and 20g as far as turbos go are on the cheaper end when getting into serious power. The GT52 is offered through Element Tuning and is a great turbo from what I've seen. My friend just put one on his STi with injectors, TBE, FMIC, CAI and UTEC and his runs really strong.
At this point I'd use a GT52 over any other turbo on a stock motor. Otherwise, APS TSR 70 all the way.
Car Info: 05 STi
Not particularly, nothing more than a bunch of bolt ons. I'd recommend the normal bolt ons and if you're able run Hydra EM with Aquamist. It's a pretty nice set up, especially if you get Element (Paul) to do your tune, he knows all the ins and outs of that set up. Check out Element Tunings website if you're interested.
Car Info: GT35R, Meth
Hm while I'm at it - I think you can flatfoot with the stock ECU but you sure as heck can't launch with boost or use any type of antilag w/o a standalone. Both of which are pretty much a neccesity on fast imports.
In Russia, Title Choose You.
Check out my reply to your post in the norcal FS section. PM me if you need clarification. Horsepower is not the barrier to running 10s. Supporting mods, and $$$ to fix broken parts while practicing to cut a good 60' on slicks is what prevents people with 600, 700hp from running 10s.
plac
01-17-2008 09:21 AM
STi-FTW
11-01-2005 07:11 PM
grandmasterchan
18
07-23-2004 03:18 PM
