HELP FROM PROTUNE 06 wrx stage 2
Car Info: 996 Turbo,Gallardo,BMW 335,125cc shifter kart,etc
Originally Posted by testes1010
from everything I've heard shiv has pretty much given up on the Subaru scene....
-shiv
________
MARIJUANA TRICHOMES
Car Info: 2015 STI
Some of you guys talk like you live with Shiv and Mike... let up a bit.
Iburrrna...
If I was in your shoes, I would not bother with a Protune with the AP stage 2 set up on your WRX. Mike might've recommended you an option that may benefit you in the long run. If you're planning on upgrading your turbo, then stay with the OTS map. And if you're simply persistent in wanting to see gains, then I would suggest calling Mike again.
Tossing in my .02!
Iburrrna...
Tossing in my .02!
Car Info: 04 wagon
From my logging when I was on Cobb's Stage 1 CA map, it wasn't running very well. IAM was stuck at 8 and knock correction was at 4-5 under WOT. My suggestion is if you can spend the money, have someone custom tune it. Any good tuner can make your car run safer and smoother than the Cobb base maps.
Granted, I am not sure how the Cobb base maps perform on your Stage 2 setup. My car has stock exhaust and everything.
iClub Silver Vendor
Cobb's maps don't tend to run too well on cali gas IMO, so I have never turned down such a tune. All of my customers to date who have switched from a Cobb OTS map to a custom tune have been very happy with the gains not only in overall power but especially drivability and response.
Please feel free to contact me with any questions.
sabrebluewhale
07-20-2008 07:53 PM
06blackwrxtr
35
01-12-2008 01:16 PM
