help. misfiring!
help. misfiring!
Hey. So I have about 65K miles on Brooke. I had a buddy change out my spark plugs for some of those Pulstar plugs. And now shes running like crap. My accessport tells me that Cylinder 1 is misfiring. Was the spark plug installed incorrectly? What caused the misfire in the first place? Since I know what cylinder is having the issue, is it relatively easy to fix? What do I need to do? I don't have a garage to work out of so I think I might have to go to a shop for this one. (Possibly a dealership) Will it be expensive?
Thanks!
Thanks!
I actually have the car at a shop right now..hopefully its just a gap... those plugs cost me 100 bucks!
thanks for the input guys! keep it comin! knowledge is power!
Car Info: bici putas
The boot is identical whether there's a coil or not, asshat. The copper can lose it's spring tension and not seat the plug terminal correctly.
For the record I hold practical knowledge, not internet "knowledge".
You ought to do a little research yourself, back in fraggle rock
