Getting An Intake. Which Kind Should I Buy?
Car Info: 2006 Impreza WRX Sti/Hawkeye
So most of you say Impreza's 02-06 have problems rite? SO then some of you say yours run just fine. Which kinds of Intake systems did you buy? i just like to know because Im planning to get one. Any ideas? THX!
Spend your money somewhere else!
You should pull the baffle box in the inner passenger fender while you are at it. Do a search for 'snorkle removal' for directions... here or NASIOC.
You will get as much from this as a CAI and it will cost you 1/4 the $ and look completely stock to the five-o's eyes!
Car Info: 04 STi
the typhoon works well without messing up maf readings causing"lean" like others such as AEM which is the worst intake for subies!...i had it but also had heatsoak and ****ty filtering..so i went back to stock...errr the rpms did climb faster and felt better up top but may have lost alittle dwn low
Car Info: 04 STi
Originally Posted by stav
how about the intake from subaru the spt or srt any reccommendations
http://www.iwsti.com/forums/showthread.php?t=60461
Originally Posted by NW OBS
Do yourself a large favor. Just stick with the stock box and a good quality drop in panel filter (preferably 'dry' if your car is MAF based ~ oiled can foul MAF sensor). You can use an STI, HKS or any high flow drop in you wish...
what if i just get a K&N Filter (not intake)?? and replace my stock filter? i guess that works oo rite? since my stock intake its kinda like cold air anyways haha
I would do yourself and your car a favor and keep the stock
airbox.A K/N panel air filter will flow more CFM's than the stock
air filter though.
blue blurr
11-10-2004 06:22 PM
