Engine Knocking Noise.. help!
Old 09-21-2004 | 03:35 AM
downsti's Avatar
Car Info: Big Thanks Jeremy@CrucialRacing and Ed@EQ-Tuning
how does the knocking sound like?? sorry im kinda slow hehee
Old 09-22-2004 | 01:14 AM
RoadSpike's Avatar
Engine specific but litterally like a knock on a door though in my limited experience with knock higher pitched than your average door knock.
Old 09-22-2004 | 10:00 PM
Krinkov's Avatar
rod knock and detonation "knock" are entirely different sounds, det sound more like a tapping or even ticking, a rod knock is just that
Old 09-22-2004 | 11:18 PM
verc's Avatar
Car Info: GT35R, Meth
so what is rod knock ok or something? I'm confused.
Old 09-24-2004 | 12:16 AM
RoadSpike's Avatar
I don't think you can get rod knock until you bend a rod so thats definitely not ok.
Piston slap is just becuase the components are loose when cold so they shake a bit making noise, at least what i understand about it.
Pinging is like dropping bb's into a tin can.
Old 09-24-2004 | 12:38 AM
Rod knock is also caused by worn conrod bearings. The rod shakes around either the crank or the piston wrist pin. To understand what I mean, loosen your wristwatch 2 or 3 notches and shake your arm back and forth.
Piston slap is more common with forged pistons, which expand more when hot. This means that when they are cold, there is a larger gap between the piston and cylinder. It should go away as engine temp rises, gradually fading out within a few minutes of startup. Your explanation is correct, I just wanted to add a little detail.
BBs, nails in a blender, popcorn... anything that is a harsh metallic discordant sound.
EK
12-02-2014 03:23 PM
EK
12-02-2014 03:21 PM
mittttal
06-01-2014 07:47 PM
spankmeplz700
13
05-02-2004 05:22 PM
Fast turbo 20
17
05-08-2003 12:28 PM
