ecutek,idle seems high
hey guys i have a 20g with supporting mods and my idle is liek at 900 rpms all the time, is that bad? it used to idle at 750 with my utecbut it could be casue it was utec, but i traded it for ecutek,any help would be appreciated, oh ya can i unhook the elctrical for my boost solenoid since i have ecutek or does the tuner have to disable the CEL you get from disconnecting it?
Car Info: 2005 Black WRX STI
That said, it's not surprising that your tuner set your idle a little higher than before. If it fluctuates, you have less chance at stalling.
My car, with similar mods had trouble at idle. (Perrin 816 cc injectors, fuel rails, walbro 255l/hr fuel pump) We added a fuel pressure regulator from APS and it limited the fluctuations to +/- 150 rpms. It is set at 43 psi and rises to 63psi with boost 1:1. My idle rpm set point is 650 rpm. I would say that 500 with no fluctuation is ideal but 500 to 1000 is OK.
good deal im glad my premapped ecu is a good one
Indirecked
08-01-2003 10:34 AM
YellowWRX
05-06-2003 08:41 AM
