Cruise Flashing And Cel On Wtf???
First of all i know its been talked about before but here are my mods and my story, i have a HKS Catback HELIX downpipe(cat eliminator) Ported wastegate(by LIC motorsports) and K&N intake(the red one). Last night was driving on the highway temp about 48degrees and my buddy in his 350Z wants to race so i ubcourse accept, we go at it and at around 140mph i feel the car stall like if i hit a brick wall then come back to life. After coming back to life my cruise control light starts flashing and the CEL light is on the car seems fine but im really bothered by it. Now here are my questions:
1. I tought that only occured if u didnt have ur wastegate ported?
2. How The F*CK do i fix this?
3. What exactly is going on should i be worried? get the turbo reported? Is it due to the low degree weather?
ANY IMPUT WOULD BE GREATLY APPRECIATED....
Car Info: '04 STI, Vishnu stage 1
It sounds like you hit the speed limiter on the vehicle. It shuts down I believe at about 150 mph. Probably shut off the fuel/spark and because of your mods, the engine leaned out for a second, throwing on your lights. You could probably get an OBDII tester from some shop and have them check your codes. Write them down, and then clear the codes. If you didn't have any lights on before, it should be fine. Just keep the runs under 150 and you should be fine. I'm not 100% sure but by looking at your codes stored, that will tell the story.
speed limiter
I read on some of the tuner sites the speed limiter is 147mph. Cobb Tuning for instance changes this to 300mph in there map files. That oughtta keep you from hitting the speed limiter right?
If you have a cat in the uppipe then a misfire such as rev or speed limiter could damage the cat and subsequently the turbo.
Those 350Z's have some top end. He probably gave you a good run...
I think your car just hates you and you should let me have it.
i got the same problem but i didnt go that fast. i got an 05 sti with a perrin downpipe and hks hi power exhust. My check engine light come on and my cruise control flashes. i went to autozone and checked it out the said it is reading from cat saying it indicate massive airflow. I was too scared to take it back to the dealership cause the downpipe would void my whole warranty.
Car Info: a prius, a miata, & 2 m3's
the turboxs downpipe i now have on my car blew Ryan's turbo seal. he was extremely unlucky. the dealership didn't cover it, obviously, but a downpipe will void your emissions control systems (read: cats and the rest of your exhaust) and perhaps even the turbo warranty, which could make them wonder about the rest of the engine parts.......... blah don't give an excuse to dealers to not cover warranty work.
but yes I got this code when my O2 sensor was out and i didnt have the cel fix. now that i have the cel fix its all good. but then again Ive been having the same problem with my XEDE... bam detonation then cels triggered but this is only around 2000RPM cruising on the highway hella random...
Ive gone as fast as 155 on my 05 maybe the 05s dont have the speed limiter, the STi doesnt have a cat i the uppipe so i dont think thats the problem. I had like 15 car lenghts on my friends Z so not that much top end =)
I read on another list that you get the same flashing light and CEL when you overboost. Apparently you need to port your wastegate if you put on a downpipe or turbo back otherwise you get boost creep.
I let off at 140 in mine so I can't confirm...what a whimp I am
Ah - I didn't realize the STi's didn't have the cat in the uppipe until I read the rest of my manual.
Things I've seen on mine or my friends so far...
1) Running the car out of gas.
2) Overboost... being over 17(WRX) or 19(i think STi is 19) for more then certain amount of time...
3) O2 Sensor related issues... In my case, I have no cats and the perrin O2 simulator... but it still occasionally throws a "Late O2 Signal"
4) Not putting your gas cap on...
It seems like non-critical CEL's go away after 5 sucessful driving cycles without encountering any further errors...
Ohhh yah... and the speed limiter is at 155mph... and it's not a total fuel cut... It just kinda sits there and hovers between 150 and 155...
I had the same problem also! Boy was I scared!!! Thought I screwed up my car when smoke came pouring out the exhaust...luckily it was just the XEDE piggyback was set too rich under load....downloaded a new map, 93 octane stage subzero...after resetting the ECU.....voila check engine light/blinking cruise - gone!
BY the way....the car ran 12.94 @ 103.42 the next night!
JT
JT
iGoTsBLu06sTR
01-21-2008 06:47 PM
RHayes
25
10-16-2006 05:06 PM
digitsti
03-29-2004 03:40 PM
