Check Engine Light w/ Cruise Control
Misfire Cyclinder 1
i just got back from FLI
i must say though... avoid prestige imports at all cost
i am hoping it was a one time thing. it hasnt done it again since and everythign is running great
no we just reset it for right now to see if it does it again so far it is running like a champ
i was driving it hard as **** earlier today for about an hour
Car Info: 2006 WRX "Wagon"
You should change the spark plugs. I had the same problem on my 06 and i hated it. I reset the code couple of times but it just came back after some time. Changed the plugs and never seen it again. (P0302 Cylinder 2 Two Misfire) Mines was cylinder 2
Hey can anyone give tell me what might be up with that. I heard it was pry a mis-fire.
No AP yet so i cant tell you the code.
2006 wrx wagon. Exedy stage 1 clutch and lightweight flywheel.
Spt intake and exhaust
31,xxx miles. Had my 30k service done 2.5k ago.
as far as i can tell BS prestige motors did everything except new spark plugs
the last 7-10 times of starting my car I have had a slightly rough idle for about 15 seconds after start up, and did it whether the engine was hot or cold.
and today for the first time the check engine light came on and cruise control light is blinking...
anyones help is appreicted
thanks in advance
-ryan
thanks in advance
-ryan
Don't you go and make me quote my PM to you, when you PM'd asking whether you should get a lightweight flywheel.....cuz I'll do it.
But noooooo you didn't want to listen to the vodka. Next time listen to the alcoholic beverage.
06scooby
10-15-2006 10:11 AM
wei8532
07-12-2006 06:29 AM
