Check Engine Light w/ Cruise Control
Old 06-12-2009, 11:05 PM
Irish_car_B0mb's Avatar
Hey can anyone give tell me what might be up with that. I heard it was pry a mis-fire.
No AP yet so i cant tell you the code.
2006 wrx wagon. Exedy stage 1 clutch and lightweight flywheel.
Spt intake and exhaust
31,xxx miles. Had my 30k service done 2.5k ago.
as far as i can tell BS prestige motors did everything except new spark plugs
the last 7-10 times of starting my car I have had a slightly rough idle for about 15 seconds after start up, and did it whether the engine was hot or cold.
and today for the first time the check engine light came on and cruise control light is blinking...
anyones help is appreicted
thanks in advance
-ryan
Irish_car_B0mb is offline
Old 06-13-2009, 12:05 AM
bump
Old 06-13-2009, 08:03 AM
Woodward06's Avatar
Car Info: your sister crazy.
Go down to an auto parts store and have them pull the code for free.
Woodward06 is offline
Old 06-13-2009, 09:14 AM
yea ryan theres not much we can help with without knowing the specific code
stupidchicken03 is offline
Old 06-14-2009, 12:46 AM
i know i was just hoping the cruise control light blinking would mean soemthing specific
Old 06-14-2009, 12:59 AM
VRT MBasile's Avatar
Just means that your cruise control is deactivated. The CEL may be getting set off by the flywheel, how long have you had it on there? Whats been done to the car recently?
VRT MBasile is offline
Old 06-14-2009, 01:51 AM
the flywheel has been on for almost 1k miles
started doing the rough idle thing maybe 50 miles ago
the most recnt thing done to my car is i put in my turbo timer
besides that my clutch and flywheel are the most recent things
Old 06-14-2009, 10:43 AM
did u go and get the code pulled?
Old 06-14-2009, 11:15 AM
i am leaving in a minute and i am gonan go hit up kragen
i will post it up while i am at work
Old 06-14-2009, 11:18 AM
subi4justin's Avatar
Car Info: 2015 SWP WRX
bump for the code.. its probably nothing big.
subi4justin is offline
sounds good ryan
Old 06-14-2009, 02:59 PM
nothin yet?
Old 06-14-2009, 03:12 PM
wrxisthebest's Avatar
i bet you it is a misfire...
lightened flywheel = death from you having to see Check Engine on your dashboard so ****ing much
wrxisthebest is offline
Old 06-15-2009, 01:08 AM
why would a lightened flywheel give me problems...
i am only asking becuase before i got it i asked if it woudl cause any issues with my daily driving or CEL's and i was told no
Old 06-15-2009, 11:45 AM
whats teh code????
Quick Reply: Check Engine Light w/ Cruise Control
