Boost creep on a stock STi?
Engine mgmt cannot fix boost creep, it may help reduce it, but not enough to safely pull in 5th and 5th gears. Porting the wastegate and maybe even replacing the flapper are needed.
I had my wastegate ported and still got creep. Then I had a Black Hole flapper installed and now its perfect.
Originally Posted by punkrocksailor
Boost creep only happens with free flowing (i.e. no cats) turbo-backs. It's a wastegate size problem, it can either be solved by porting the wastegate or using EM that will let you raise the boost.
Cheers,
Joel
Cheers,
Joel
Sti"izzle"
05-25-2005 09:03 AM
stryfewrx
05-27-2003 07:30 PM
