the biggest turbo i can get? (2006 WRX)
Car Info: 06 wrx is gone..911 PORSCHE
Hey well i have an 06 wrx and i wanted to know whats the biggest turbo i can get using a tmic?what size injectors will i need? and should i get a walbro fuel pump? i know i will hav to upgrade to a bigger tmic..any suggestions on wat kind of tmic i should get?
Well if you want power and a big turbo go with perrin GT35R with 720cc or bigger injectors.
I am running 850cc right now and i am going to get my turbo hopfully soon, but with the set up i have now with a tune i should run right around 500whp on stock internals.
Get a 20g or FP green turbo. Unless your gunna use a stage 2 block with upgraded cams, those turbo's are plenty big and will give you loads of top end. 700cc+ injectors, Walbro pump, STI intercooler, and Accessport, and you'll be making very good numbers.
Car Info: e39
well you gotta realize since u have a 2.5 liter motor just like the sti, I would say you should get the fp red turbo. It's a lot better then the green plus everyone I know who has it gets a lot of power from it. Since your in sj Mike has tuned some of my friends cars with fp reds one of them gets 360whp from the gruppe-s dyno on his 06 sti. Thats good stuff
well i would like to get an fp red but i dont want to go fmic...the reason for this is that it really attracts cops and once they see the fmic thats like an automatic pull over for me because subarus already dont come fmic....
Location: Leaving on a jet plane dont know if i'll be back..
Car Info: 05 STi White v2 8cm FP Red
Stock injectors, walbro fuel pump and upgraded TMIC=TD06H-FP20G (8cm)
720+cc injectors, wlabro fuel pump and upgraded TMIC=FP Green (8cm)
Anything bigger than a Green then you need to go with a FMIC. Actually, to maximize a Green you should have a FMIC but there are plenty of ppl who run Greens with TMIC and have good success (eg. Mark G stock TMIC Green 11.7 1/4 mile).
