Anyone Mod their 06 WRX yet?
Just wondering what has changed from the 05-06 2.5L that could not be used from 05 WRX's?
As an example:
Exhaust systems? are these interchangable?
Suspension? Would the swaybars/links be interchangable?
Wheels? Whats the bolt pattern?
Catted Uppipe? or did they take the Legacy route and remove the precat?
Thanks,
As an example:
Thanks,
As an example:
Thanks,
As an example:
Thanks,
Originally Posted by Krinkov
outside of the bigger changes from 04 to 05 like wheels and suspension, the changes to the 06 have been more subtle. All the parts you mentioned should be the same from 05 to 06, and all years of US STIs have catless up-pipes
Do you know if the 06 WRX has a catless uppipe? I know the Legacy 2.5l went that route in 06.
all the 2.5 liter turbo engines have catless uppipes, they use and air injection system instead of the metal substrate cat in the uppipe like the 2.0 rexes.
with the exeption of the sti that has never used a cat in the uppipe or an air injection system for cold start emissions.
So I just tried to install my some exhaust pieces today.
Guess what!, My Scooby sport DP will not fit! They changed the exhaust system lenghts.
DP is shorter by ~4"
2nd Cat is longer
Midpipe has a s curve in the piping right after the donut flange.
Only my axle back would fit.
From talking with others I think if I install a full turbo back and not try and leave any OEM pieces in that It should work.
Brian
2nd Cat is longer
Brian
Im just as curious...
and will the S curve have any effect on aftermarket pieces? meaning... if we try installing a tbe meant for an '04, would it matter that it doesnt have the S bend? <-- that S curve sounds like a horsepower killing strategy...
I know this engine is capable of soooo much power, i can just sense it...
After looking at it again if you have a cat back it should fit. Looks like the s curve just moves the pipe toward the drivers side to accomidate the larger resonator and then brings the pipe back in line with the 3rd cat flange.
I've been told that the SPT cat back fits and I know my axle back fits so things must line up correctly.
I have some pics if you want to send me your email or host them?
Brian
Brian
ryball
02-02-2006 10:46 AM
selt129_smk
10-15-2003 10:45 AM
