485-500 whp STI!!
485-500 whp STI!!
IS it possible!!??
My wife an i have the money and are going to buy owning an STI soon(aspen white, gold rims). I was wondering what i would have to do to make this possible,25 g turbo, do they even make a 25 g turbo for the sti? Please give me some suggestions i am serious on make this car possible.
and your wife is ok with this? why? unless your filthy rich that is... check out easystreet's website and ask them. good luck man. its possible... plan on spending 10-25+k for it thought..
anythings possible you would be best looking into a COBB 2.5 short block if your shooting for more than 400whp, our bottom ends are nice than the regular WRX buts its no EVO. the 450whp would be the the most hp Ive seen out of a US STI so far, shine on you crazy diamond!
Car Info: SGM 135i
well ... sounds like money isn't really your biggest problem. in that case, i would talk to axis power for a build block, you can keep your sti head cause it has avcs, as far as turbos go, the fp green is a great choice. also a garrett turbo. a linksys standalone. good tires, and also nos should be considered for a quick boost.
Originally Posted by ERIKNLARON
Internals an issue in the build i bet they are but what u think i'll have to do? I know nothing about STI's but what a good way to learn build a 500 whp car .
I dont know of any cams right now that will work with AVCS, all the ones people are considering means not using AVCS. Im sure there will be some at some point though. the FP green is a great turbo for around 400+whp but you will need something bigger to get up to 500.
Crawford 2.8
Ported Heads w/ Jun cams (lose the AVCS)
Deadbolt Superzilla w/57lb wheel (custom external gate setup)
or larger turbo (T67, custom GT42, etc...)
C16
Nitrous for spoolup
All of the necessary parts to keep it together and running right (head studs, cometic gasket, front mount, carbon-carbon clutch, etc.....)
GL,
Dave
C16
Nitrous for spoolup
GL,
Dave
digableplanet
Cars For Sale
09-30-2013 11:57 PM
StiJdm831
07-09-2012 04:06 PM
