Is '06 Forester XT engine detuned version of the '06 STI engine? (was: Similar?)
Car Info: 06 Forester Turbo
Similar?
Excuse me if this question has been asked before; I was wondering if the 06 Forester XT engine is a detuned version of the 06 STI engine? From previous threads I gather that they are quite similar.
Thanks, Bob
Thanks, Bob
Originally Posted by depdivr
I think that the block is exactly the same but internals are different enabling the STI to take high boost levels.
it's the same as the 06 wrx engine(same compression). the 06 sti has a lower compression than the xt and wrx. on the other hand,the 05 forester xt and 05 sti are the same engine.
Originally Posted by neuspeed
Wait the 05 forester XT and STi have the same engine?; but different turbo/IC/and fuel pump/ injectors?
i am thinking of buying a 06 forresrter xt for my girl. i have a 05 sti if i decide to get a after market turbo and injectors and intercooler will all my stuff bolt on the forrester.
Yes but AFAIK the injectors are the same, the turbo will bolt on and the IC needs some bracket modification and you need to watch the back of the IC does not rub a hole in the AC line (needs to be bent out of the way or something)
big dawg
08-01-2006 07:12 PM
