[h] noise under boost - like supercharger
Car Info: 05 cgm imp
so yesterday, in the rain, as i stepped on the gas i noticed a noise i've never heard before. i searched in the forums but no answer.
it happens under full boost, instead of hearing my turbo spool through the intake, i hear another noise, like a supercharger whine. scoo_b heard it in my car, he wasnt sure what it is.
i got k&n sri, tbe w/ silencer put on.
maybe a leak on the dp/turbo, the nuts tend to get loose there, i will look in to the when its not raining.
help will be appreciated, thanks.
you did not state in the OP that it varies the boost.
the reason you would hear it under full boost is cause you motor is under load. belts become under load at the simultaneously. cause your PS to make the "Supercharger Whine"
Car Info: 05 CGM STi to be converted to RS
is this urgent or can i wait until action needs to be taken.
check the bolts on the dp/turbo and they're on there.
my o2 bung tends to get loose because crucial didnt send me the right one, tightened.
so the sound is still there, happens near 5k rpm, does not vary with rpm but with boost.
WRXncrew
14
05-07-2014 12:41 PM
WrbImprezaSti
15
12-01-2008 06:05 PM
PURIST
12-20-2007 11:21 PM
