*Need Help* 2005 STI wont start
Old 01-07-2006 | 06:55 AM
theSTI's Avatar
Here's the story..me and a couple of friends went driving through some twisties..i got to a tight turn spun out(didnt hit anything) i got the car to move about 5 feet and it died. Tried to start it but it wouldn't turn over. the car cranks but wont start..popped the hood and the first thing we noticed was that the pipe from the manifold(gruppe-s header) was glowing red, we then noticed that the screw holding the coil pack was practically falling out(passenger side cylinder closes to the firewall) we had tools so we tightened the bolt and let the car cool down. Tried to start it again but nothing. I tried resetting the ecu just to see if anything would work..the car started but struggled to idle, and when it did it was lumpy and eventually died. after that the car wont start at all. i was also low on gas..but the gas light didnt go on until just before i spun out. the car didnt throw any codes during the whole thing, ended up towing the car home. and help or suggestions are greatly appreciated.
cliff notes:
driving through twisties
spun out
car died
wont start, crank but wont turn over
pipe from header to uppipe glowing red hot
bolt holding in coil pack falling out
tightened bolt
reset ecu
started car with ruff idle eventually died, and wouldnt start at all
Mods:
helix catless dp
gruppe-s crank pulley
hks ssq bov
gruppe-s manifold
force fed catback
aem cold air intake
thanks in advance for all the help
-jeff
Old 01-08-2006 | 09:41 PM
SubitunerSTi's Avatar
Car Info: 2005 WRX STi
you could have starved the motor of fuel and may be your huhmm Got no friggin clue
Old 01-08-2006 | 10:37 PM
depdivr's Avatar
Car Info: 2005 Black WRX STI
cliff notes:
spun out
car died
tightened bolt
reset ecu
Mods:
helix catless dp
hks ssq bov
gruppe-s manifold
force fed catback
aem cold air intake
-jeff
Not 100% sure but I wouldn't be suprised if there is something loose in your electrical ignition system. Your mention of the coil pack got me thinking on this line. The rough idle is a key simptom of a single cylinder not fireing.
One other thing, look at each one of your injectors. There is a small clip which keeps the wires tight against the injector connectors. If a clip falls out, its only time until the wire falls out or becomes disconnected - car won't run very well at all.
This happened to me while I was installing my front mount - took me forever to track down the problem... I think it was the #2 cylinder.
Old 01-10-2006 | 03:54 AM
theSTI's Avatar
thanks for all the help...the problem ended up being fouled out spark plugs..thanks to gino at gbmotorsports for the help.
STIKRAZY
05-18-2009 02:20 AM
muskatomas101
12-02-2007 05:30 PM
krillz
07-02-2003 05:37 AM
DDImpreza
05-28-2003 04:10 PM
KnightRider
12-31-2002 05:24 PM
