y over boosting??plz help
i was ... on highway at 4th gear 5000rpm it star over boosting after i shift to 5th it gone carzy it hit 20psi i didn't even know until i hear fuel cut. but 1st 2nd 3rd n (4th until 5000rpm) is find i set it at 15psi. plz help can ebc help?? also i took out the stock restict hose n leave stock bc hook up. n hook up with mbc
mod.
up pipe
down pipe
turbo sx stage 2 unichip
hks bov
coustom short ram intake
cat back
turbo sx mbc
mod.
up pipe
down pipe
hks bov
cat back
turbo sx mbc
Last edited by Wingless Wonder; 02-19-2005 at 12:07 AM. Reason: no street racing references allowed.
iClub Silver Vendor
As these guys said, the MBC/unichip combo is a very bad idea for the 04+ WRX's. They have a fairly long dellay before they switch into open loop mode (enrichment) and therefore you end up running full boost at 14.7:1 a/f for several seconds. On top of that, the unichip is advancing timing and trying to pull fuel, so you're really setting yourself up for a blown engine pretty soon. Save up for a tune.
-- Ed
Equilibrium Tuning
-- Ed
Equilibrium Tuning
iClub Silver Vendor
Originally Posted by minisiu
i get a 02 wrx
My fault... you never said what year your car is. But even on the 02/03 ECU's the unichip/MBC combo runs into the PTFB problem where you end up running lots of boost at part throttle while the ECU is staying in closed loop mode. But if you're really set on running this combo, it sounds like you need a better MBC that will hold similar boost in higher gears as in low gears.
-- Ed
Equilibrium Tuning
so can ebc fix the problem? also when you installing it do i unhook the stock one?? i mean unhook the hose or the plug??
well b4 i bought unichip n mbc the shop GND toll me to get a reflash but i don't want to sprnd $600 so i bought uni which is only 200
blackwagonrx
06-18-2004 01:14 PM
Scoobyvroom
02-05-2004 01:17 PM
minisiu
11-04-2003 08:40 PM
