wut kinda MBC
Car Info: 2002 WRB WRX
wut kinda MBC
what kind of manual boost controller is the best and cheapest.. i guess just best bang for the buck... right now i have uppipe, and turbo back.. with a drop in filter.. and i was wondering if i should invest in a mbc and just put the boost up to 15-16psi... only for times when i go to the track and when i feel like goofy around!! .... eventually im going to upgrading the turbo with injectors, and a new top mount.. but anyways just wondering whut the best mbc is.. and maybe if there is a conflict going on about having one...
Car Info: '02 EJ25FXT Stage 2 "No Laggin' Wagon"
Rather than screwing with a MBC, I would recommend going to a local tuner to have your ECU tapped and tuned to maximize the mods you have currently installed. Well worth the investment, IMO.
what year is your car?
edit: profile says 02.
due to the older ecu revision, you can run an MBC. to run safer by sidestepping the part throttle full boost issue, buy one of ed/eq tuning's open loop managers.
FuturistiK_STI
06-30-2011 08:45 AM
Wrxplaya11
07-20-2004 07:21 PM
