WRX on long road trip (Will it be on boost)
don't worry about it. it should be fine. between stopping for gas, and slowing for traffic, your engine and turbo will get enough rest. i drove my my talon tsi from maine to wyoming. at one point i drove for 23 hours, only stopping for gas, and i had no problems at all. the car is designed to be driven, and should handle your trip well. subys are pretty damn tough.
-PJ
-PJ
No worries.
I know that the Volvo V40 T4 (2L 4cyl 200+ Turbo only available in Europe) did a run around an oval track at maximum speed (+/- 140 mph) for 24hours only stopping for gas and driver change. This is the kind of endurance testing well-engineered modern cars are put through before they are put on the market.
My guess is the WRX is better engineered than modern Volvo's.
Actually, if you were to be able to make the ENTIRE trip without stopping at 80 mph, your engine would love you. ~4000 rpm is the turbo's sweet spot, where it's thermal efficiency is the highest, and there are no temperature fluctuations to mess with clearances internally. The only problem is, you're going to use about 25% more gas than if you drove 65-70 all the way.
Originally posted by Silver arrow
Actually once you get up to speed look at your boost gauge, you are more than likely not boosting but probably vacuum.
I just got back from an 11 day trip from bay area CA to SE AZ and back in our stock WRX wagon. Lots of fast freeway driving - mostly 80 MPH or more. Some mountain driving, some fast driving on rural 2 lane roads and some time on gravel.
Mileage was always over 20 MPG with 23-25 on freeway days.
The boost gauge was getting to 0 at just over 80 MPH in 5th. You aren't making the engine sweat at 80 MPH.
Bill
Bill
Car Info: 2002 MBP WRX, 2012 OBP STi wagon
When I drove from Texas back to California, I managed to pull 30mpg on about 2 tanks out of 8 or so fillups (I was tracking my mpg per tank, and I averaged about 26 the entire 2100 miles). This was driving through NM, AZ, and NV. Don't sweat it. I drove for 14 hours a day each day (except for a stopover in vegas) and the car handled it beautifully. Only mod is an EBC set to about 1.10 hkpa peak. Once you get to highway speeds, you are rarely getting into boost except to pass someone. I just stuck it on cruise for the long, flat sections of highway.
shadowcat
shadowcat
Car Info: 02 WRX WRB 4EAT VF34 Kit w/AP
Once you get to speed, you wont be in boost anymore. I had my cruise control set to 75mph. When the car starts to go uphill, boost begins to build some depending on how steep the hill is. But once it levels out, it goes into vacuum.
I went from Cape Haze Florida to Atlanta, Ga. On the way up there I had cruise on at about 70-75. I got 26.5 mpg that ws with one stop for gas. On the way back i filled up before I left cruised at 85 all the way got 400 miles out of the tank, and 27.5 mpg. That was with one fill up during the trip.
RabidNoodle
05-10-2005 07:39 AM
Kostamojen
02-16-2003 12:55 AM
