WRX engine tick
WRX engine tick
I know our engines are known to tick alot, so i decided to make a quick vid to see if the amount of ticking mine has is "normal". Seems to tick an awful lot.
You need Quicktime.
http://www.we-todd-did-racing.com/we...ZmQzMXk1NDE%3D
You need Quicktime.
What kind of motor oil are you using? Its normal for the EJ20 to tick when cold. Using a quality synthetic oil will make some of the ticking sound go away.
from my limited understand the tick would be caused by a slightly sticky valve. You could try pouring a small amount of Marvel Mystery oil into the crank case and see if it can loosen up your valves a lil.
This may not be the problem but if you had some MM handy it would be worth the shot
