Why would a car misfire?
Ever since I installed a helix catless down pipe, my car has been back firing quite frequently. On another note I caused my car to misfire cylinder #3 launching it too hard somehow. This was when my only mod was a leaking helix up-pipe, 3/16th mod, and snorkel delete. I had to drive the car in limp mode to a mechanic.
Originally posted by qwk_wrx
no a back fire is not good and neither is a misfire...you might be talking about a after fire where unburnt fuel hits the hot exhaust pipe and burns and shoots a flame out the end...
edgar,
Originally posted by Fez
why ask about a crank pulley
there are also stories of "cursed" cars that cannot shake the misfire code no matter what is tried... reflash, new coils, new plugs, new crank/cam sensors, etc.
hth
ken
"there are also stories of "cursed" cars that cannot shake the misfire code no matter what is tried... reflash, new coils, new plugs, new crank/cam sensors, etc."
If this is the case would it be a cracked piston or warned rings? I'm having the same problem.
hth
ken
Ken,
Have you ever had that problem? I only have 18k miles and removed my lighten crank pulley but still getting a misfire code. I will try and replace the plugs to see if it resolves the problem. If this doesn't work I will get a compression test.
flatline
10-13-2008 04:49 PM
brucelee
01-30-2008 03:51 PM
brucelee
08-23-2007 02:33 PM
brucelee
12-23-2005 09:41 AM
