who has a flex joint up-pipe?
My custom made up-pipe finally give up on me and starts to leak. I'm looking into getting a new one, probably with a flex joint. Have any of you had any problem with a flex joint up-pipe?
I'm also thinking of gutting out the stock one instead of buying a new one...
Which option will you guys recommend? gutted or flex?
Many thanks,
Many thanks,
Car Info: 04 GGA+
Re: who has a flex joint up-pipe?
Many thanks,
Many thanks,
big sky
Alot of New Englanders have success with the BPM's from www.subaruwrxparts.com/per-wrx.html I cannot comment personally, i still have the stock up-pipe.
@Stoptech
Car Info: 2002 WRX Wagon
The gutted stock uppipes have bad flow properties due to the rapid changes in diameter without the cat material. The STi uppipe is probably the best as far as reliability goes but many will argue that the Perrin and PDE are not far behind.
Thanks for all the reply guys!
So does anyone have a picture of the inside of a STi/JDM uppipe?
I noticed the stock one is fairly smooth on the inside, except the part after the cat, it looks kind of like a bottle neck.
Also, is it true that a STi/JDM uppipe don't have an EGT bung?
Car Info: 04 GGA+
The STi pipe doesn't have a egt bung, doesn't need one. Many of the aftermarket pipes have gone away w/ the bung as it's one last thing to leak (back out). You simpy use a $.10 resistor to let the ecu everything is OK.
Picture (mine was jetcoated):
big sky
big sky
BLESSTI
08-06-2007 09:57 PM
fliped wrx
SoCal Classifieds
06-08-2007 10:52 PM
t-wrexxx
05-16-2003 01:49 AM
