Where did you tap in for boost gauge?
I was wondering where you may have tapped in for the boost gauge.. seems like everyone has their own opinion on this.. I have a Greddy boost gauge and guess I need another T to mount it,, but am curious where people tap in for the boost
2006 Mt Hammy Car Show Winner
Car Info: Black 03 WRX, White 04 E46 M3
try searching and it will bring up a manual that somoene scanned shownig how to install a boost gauge. If you cant find it reply and i can look for it tommorow.
BOV line is the place.
I just installed a Greddy electronic Boost gauge and it was relatively easy.
Just make sure to get some hose clamps for the two parts of the bov line that you have cut. The Plastic Y fitting that comes with the kit fits a bit loose. And make sure to put the little brass restrictor into the Y fitting end that goes to the sensor(battery tie down bolt/post is good place to mount this).
cheers,
xom
cheers,
xom
You can tap at the BOV or at the manifold. There are some EBCs that like to tap at both places when doing boost limiting.
The difference is that you get a pressure differential because of the intercooler inbetween the two tapping points. The more accurate boost is actually in the manifold. "Accurate" here does not mean correct vs. incorrect. Accurate means that you are seeing more of the same pressure that that the head will see. That's what really counts anyhow.
Most tap from the BOV because boost will read a bit higher between the compressor and the intercooler than it will between the intercooler and he manifold. This is a safety measure, I'd guess. I.e. you're seeing a higher reading that the head is really experiencing.
jason
jason
Re: BOV line is the place.
cheers,
xom
cheers,
xom
jason
bluedevil
03-18-2005 10:32 AM
Nis14
06-17-2003 10:56 PM
