What should be my first mods 4 my wrx?
it depends what you want to do
1/4 mile? (weak sauce) or the back road twistise and the track?
overall
get TIRES, best thing you can do
i know a guy who has stock wagon, but with only some nice tires on it, he can out drive anyone with 100+ or more than stock
then go for power
bov doesn't do anything really, unless you want the sound its useless.
personally, i got a rear sway bar (cusco) first then helix up and down pipes
and cobb stage 2 reflash
they do great business even with the stage 1 its a 25 HP gain and 35 torque/lbs.
as the same time as that i got exhaust
and im getting tires tomorrow and wished i got them first
they are the best thing you can do for your car
*edit* i also got a gfb bov cause i love the sound and now i shoot flames when i shift
bloops
overall
then go for power
bloops
Ditto on suspension stuff. I like the Cusco rear adjustable anti-sway bar, with or without Whiteline alloy end links. For most people, forget the aftermarket front anti-sway bar. You can lower the car with a good set of springs or a bucks-up coilover kit, but remember that we drive in the real world, with potholes and speed bumps.
Tires make a big difference but I decided to get my money's worth out of the so-so RE-92s before I tossed the carcasses for better rubber. If you get bigger wheels and lower profile tires, bear in mind that if you decide to go with a front big brake kit in the future, not all 17" rims will clear Brembo or StopTech kits.
For those that want a plug-and-play boost in performance, I think you will be happy with reflashes from Vishnu or Cobb.
For a subjective driving improvement, some people like to upgrade the factory shifter with a unit with bushings from Kartboy.com.
tires/wheels... rear sway bar... cat back w/3rd cat elim, uppipe... cobb reflash...NAWZZZ (no, just kidding)... are you in a wagon or sedan?
It all depends what you want to do with your car...
If you want it to sound mean and don't care about all the legality issues with removing cats definitely go that route. Get a full catless exhaust system, turbo back with a straight through muffler, or anyone you like for that matter, and an uppipe. This will definitely give you a mean sounding car. The boxer engine almost sounds like a V8 when allowed to breathe freely. If you want to get a BOV I'd recomend a GFB 50/50, this way you can either run full atmosphere or 50% recirculation. With 50% you can barely here it except for when you really get on it and you won't have the problems of a 100% atmosphere. If you want 100% atmosphere then just do that. You can get them pretty cheap now. I bought mine for $100 shipped from a member.
If you're not planning on going much further than exhaust work get a Cobb reflash, if you plan on doing more work down the road invest in a UTEC so you can keep tuning. Enjoy the WRX, it's a fun car.
overall
then go for power
SALL ABOUT THE TWISTIES
bloops
overall
then go for power
bloops
:banana: also im getting a rev limiter from bee*R (anti-lag) setup, i will shoot flames
