What does your boost gauge read when...
Car Info: '04 Silver WRX
Hey there
Quick question
What does ur boost gauge read when ur at "idle" and when ur off the gas/throttle pedal when cruising on the highway. (i know you should be in vaccum, but what vaccum psi are you at?)
I just want know to do some comparison.
So far, for me, i'm hitting (during idle) around -15psi or so and a lil over -20psi when cruising on the highway when off the pedal.
Quick question
Re: What does your boost gauge read when...
Originally posted by frisco-wrx-dude
Hey there
Quick question
Hey there
Quick question
EDIT: mine is at about 16 mmhg at neutral and at about 13 mmhg in gear.
Car Info: 03 WRX / 08 Forester
Frisco, If your gauge reads PSI (positive pressure; above "0"), then it most likely reads in InHg - inches of mercury (vaccuum; below "0") and not mmHg. .......most likely.
Mine reads in PSI/InHg and is similar to the readings you get (I'll have to check). Obviously, various conditions will affect your readings (engine load, altitude, etc).
- Kean
- Kean
Which boost gauges do you guys have? I have a Blitz and it reads -.59-(-.63) bars at Ilde. Does that make sense? Is it the same as mmHg? Numbers seem way different. Can someone please explain? Thanks, Dan
I am not sure what the correct pressures should be but:
1 bar = 14.5 ~ 14.7 psi (I think it's 14.7 (atmospheric pressure))
1 bar = 760 mmHg (I think)
1 psi = 51.7 mmHg
So,
-0.59 bar = -8.5 psi , - 442.5 mmHg?
Do the mmHg gauges read in hundredths or something?
1 psi = 51.7 mmHg
So,
Originally posted by DanZ
Which boost gauges do you guys have? I have a Blitz and it reads -.59-(-.63) bars at idle. Does that make sense? Is it the same as mmHg? Numbers seem way different. Can someone please explain? Thanks, Dan
- Kean
Car Info: 05 LegacyGT,06 Black STI Will be home Soon
on cold starts it usually stays at -.06 and when warmed up it idles at -.07 and usually stays there when i'am on idle, when coming off the gas it's almost at -.1 bar
1 psi = 51.7 mmHg
So,
1 psi = 51.7 mmHg
So,
1 bar = 14.5 PSI
1 bar = 750.1 mmHg
The gauges that I've seen that read in mmHg for vacuum will display actual #'s (i.e. 500, 700, etc), and some other measurement for positive pressure (i.e. bar). It all depends on the manufacturer and what type of measurement they decide to go with.
- Kean
cdawg
01-04-2008 03:44 PM
My_Red_Suby
10-21-2005 01:54 PM
mattr762
04-18-2003 09:12 AM
