What does a Oil catch can do?
i wanted to buy a cusco oil catch, but i didnt know exactly what the purpose of it was, i read the description but i still dont get it. Thanks
Brandon
Brandon
When the can gets full you drain it. The idea behind a PCV system is that oil vapors get burned up in the engine instead of just evaporating (yes, raw oil and fuel vapor is more polluting than exhaust fumes). A catch can, well, catches the oil before it passes thorugh your compressor, TB, and manifold so it can't gum things up.
The catch can uses interior volume and baffles to allow the oil vapors to condense and drop out of the air. It keeps internal parts of the intake path cleaner, but for high boost or re-mapped ignition advance applications, a non-diluted intake charge is less prone to detonation.
Federal-Mogul spiel on piston rings and oil control (just a paragraph).
LS1 (Corvette engine) tech forum thread on vapor separators.
At one time, I thought they were just eye candy. I've since changed my mind about catch cans and plan on getting one in the future.
My only minor concern is being able to remove it easily for bi-annual smog checks in CA. Since the crankcase vapors are routed through the PCV hose, this is part of the emission controls. Even though it is not vented to atmosphere, the system has been altered.
Is it just me or does it seem like Nic3krnnamja83 is post whoring?? because I've seem some pretty lame posts from him lately and for a "contributing member" he seems either insincere or pretty ****ing stuipd. And I mean no offence by that, but one would assume that having over 650 posts on here, ones head would not be lodged in his ***.
FWIW,
Joel
FWIW,
Joel
Well, i am just interested thats why i ask questions, and if you see most of my posts are in random thoughts and the such. So for someone with only 40 posts maybe u'll understand later on.
Car Info: 03 Wrx black sedan + 2013 BRZ
Jason
if anything you posting for this is your way to post *****, you responded back. i asked a valid question which I was interested in, and obviously helps the I-club community, and yeah i should have edited but being as lazy as i am i didnt. So i guess by me helping myself, and it obvsiouly helped others to instill a thought about my topic giving them a whole new view. So I'd appreciate it, if you shut the **** up. And if you notice the posts here, people ask questions also to add and contribute to this. If you don't want to contribute to this, then we don't want your comments. I understand punkrocksailor that you need a role model and your dad beat you, but don't take it out on others. thanks.
No C.A.R.B numbers Wrxneffect, but that would be a good idea.
