what does a 2002 wrx run stock for psi?
Old 06-27-2005 | 04:55 PM
nachomc's Avatar
bov = bad
and lame
Don't let him do it.
Old 06-27-2005 | 05:10 PM
nachomc's Avatar
Aside from making his car run like an *** on wheels..no it should be fine
Check this: http://forums.nasioc.com/forums/showthread.php?t=468038
Old 07-04-2005 | 08:59 AM
SSFWRX's Avatar
Car Info: Sleeper Much?
Ok...people can go around and around debating the negative effects of BOV's on cars. Point blank the bypass valve is the most efficient valve to use on a WRX. Exception to the rule is that on cars such as mine with a FMIC and big turbo you cannot run a bypass valve, so a BOV is used, and is tuned to match.
A stock 02-03WRX runs approximately 14psi or 1 bar....give or take a little for atmospheric conditions and the ECUs willingness to allow the BCS to make that peak boost.
Haole-Pino
04-29-2006 11:20 AM
OuTkAsT WrX
05-10-2005 12:24 AM
mazspeedpro
04-23-2003 09:53 AM
WRXshagnWGN
03-31-2003 02:25 PM
BoOm
02-16-2003 10:08 PM
Quick Reply: what does a 2002 wrx run stock for psi?
