Engine/Power - EJ20T (pre-2006 WRX and JDM)There is replacement for displacement, it is forced induction - OEM 2.0 liter turbo engines in the USDM WRX. 90-94 Legacy Turbo EJ22 turbo engines can also be discussed here.
recently, my turbo has been boosting normal till 5000 rpms at WOT and it will cut out then and then start boosting again shortly after 6000. has anyone else had this problem? the only thing that i can think of is that i abused
you might wanna post more information seeing as your name denotes you have a GSR motor, which is honda... so are you asking a Subby or Honda/Acura question? tell us more about your setup.
