Water Injection Myths Debunked
Old 12-14-2002 | 01:58 PM
bamfwrx's Avatar
Car Info: 02 WRX
yeap one more thing that I need
Old 12-15-2002 | 11:13 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
So how large are the water containers that come with the kits, in gallons?
Old 12-16-2002 | 04:18 PM
capt'n'caveman's Avatar
Car Info: platinum rex wagon
i'm a big proponent of w.i.......but from your link(not saying that you are),it almost seems like you're using a scare tactic to get people to use w.i.
for instance:
".....That's right. A little turn on the boost controller ****, or switching to a bigger turbo, and Toyota's ECU tuning for ignition (and to a lesser extent, fuel) becomes far too aggressive. The little stock IC struggles to keep up and, before you know it, bye-bye engine.
And this is not just happening to the crazy monster horsepower guys -- this is happening to guys making less than 300 hp at the flywheel. ..........."
i realized your a salesman and is out to push the product, and i'm sure you didn't have any intent to scare anybody into using w.i., i'm just saying from reading your post that, that's how it came across to me.....and i luv w.i.
so have you gotten any data on egt using w.i.?
Old 12-16-2002 | 08:59 PM
so what bout the egt data?
i was only able to read bout 4-5 pages before i got overwhelmed
Old 12-17-2002 | 08:51 AM
AntiochCali's Avatar
Car Info: '03 WRX wagon, faster than walkin'
A couple of questions:
1. How much water is required for a tank of gas?
2. Can you vary the ammount of water from the injector in order to increase flow for increased HP (for example installing a larger turbo, I'd like a little more water to keep the same anti knock index).
3. How long, typically, does the pump last? Who makes these pumps?
4. Where do you install the injector, I would think in a WRX I'd like to inject water before the intercooler to keep charge temps to a minimum.
5. Who sells these kits? I am very seriously considering doing this since my car gets really poor hP due to pinging, this may help control that.
Thanks for you input.
Old 12-17-2002 | 09:29 PM
could you post some pic of your set up in your car? that would give us a good idea....plus we like pics.....if you can, get one of the location of the tank, the nozzle, and the pump
Quick Reply: Water Injection Myths Debunked
