Vishnu vs. Cobb reflash?
Old 11-10-2003, 12:52 AM
@Stoptech
Steppin Razor's Avatar
Car Info: 2002 WRX Wagon
I also seem to remember a local dyno day that went down not too long ago right here in the bay area. The dyno conditions that day were horrible, the air was hot and there were not enough fans on hand to circulate the proper amount of air for the intercoolers and radiators. Vishnu, i-speed, and Cobb ECUs were used on the same car with no mods. I-speed didn't have a map for a stock car, so their ECU pinged badly, but their reflash was not able to pull timing to prevent more knock. Cobb's ECU (no Cobb employees were on hand, just the reflashed ECU) also knocked badly, and again, their ECU was not able to pull timing to compensate. Vishnu's ECU then went up, knocked, and was able to pull timing to a more conservative map to eliminate the detonation event. The only problem with this story is that I was NOT there, so it is very possible that my version of the story isn't true. If you're interested, do a search in BAIC for three months ago and you'll see the thread. Vaus is the guy who I believe was running the dyno as it was run at ATP iirc. Perhaps one of the people who was there that day can comment on it if you are reading this.
The point is that some tuners modify the knock threshold of the ECU when they reflash them, or do something to the ECU that prevents it from pulling timing to save the engine from catastrophic damage when knock does occur. Vishnu ECUs retain their ability to pull timing if they see knock.
Steppin Razor is offline
Old 11-10-2003, 06:36 AM
capa-don's Avatar
Car Info: two thousand four - java
Originally posted by Akiata
You are on crack.
so.. who isnt now-a-days?
:banana: <- even he is..
back OT - according to COBB, with stage 2, there are certain mods where the ECU is able to make changes to better suit efficiency of the stock turbo than even you could making adjustments..
IMHO - dont waste your money on dyno tuning unless you have a different turbo or n2o.. other than that the gains arent worth the extra money.. spend it on suspension mods..
with $395 for a reflash (and eventually $100 more for a map switcher) you just cant go wrong with COBB ..
BTW - first post.. long time reader, first time poster
capa-don is offline
Old 11-10-2003, 03:42 PM
ScoobyBoy's Avatar
how much would the cobb reflash effect mileage?
ScoobyBoy is offline
Old 11-10-2003, 07:13 PM
Salty's Avatar
Originally posted by Scott@S-Squared
two big bottles
ditto and a giant switch that says "no"
Salty is offline
Old 11-11-2003, 07:22 AM
phucvtec's Avatar
Car Info: 2003 Subaru Impreza WRX
Steppin Razor, question for ya: I just had my ecu reflashed by COBB for stage 2 ( have vishnu turbo back and GFB BOV), and when i first installed it and started tooling around, I almost crapped myself. My car was faster than I ever thought it could be.... That was two weeks ago.
Now, it still boosts up to about 17 psi, and the boost come on faster than it did with stock, and it is considerably faster than it was before the reflash... but not like when I first installed it.
Could the reason for this have anything to do with an alteration in timing? I have heard that there is a factor that ranges from -16 - 16 in units of "4" that is used by your ecu to essentially judge the timing advance or retard (im out of my knowledge limits here, so please dont chew me up ). I figure that maybe I was getting some knock events, and the ecu has since compensated.
Anyway, its dissapointing. I absolutely loved the way my car ran for about 3 days... and I still do now, but well, whatever... ill deal if it is better for my engine
phucvtec is offline
Old 11-11-2003, 07:45 AM
phucvtec's Avatar
Nice, that is something I have not thought of. I guess outside air temperature is crucial. When I reinstalled the ECU, it was about 45 degrees, and now it is about 30 Sucks! I hate the cold...
Anyway, yeah, I am very kind to my car. I have no idea why, I should beat it like a rented mule. Maybe Ill pull the batery cable and reset the ecu and try again. Doubt it, but that will not erase the COBB map, will it? Cannot imagine it would.
Thanks!
phucvtec is offline
Old 11-11-2003, 07:47 AM
Wingless Wonder's Avatar
I think that a custom tune can be every bit as safe as an off-the-shelf map, while eeking out a little bit more power. This depends on the skills of the tuner, of course, and also how conservatively they custom tune.
An off-the-shelf map will work well on pretty much everyone's car but it's a compromise. A tuner will have experience with a good sampling of vehicles and know what makes power. At one end of this sampling range will be some cars that will be more detonation-prone. This is probably close to the map that is offered off-the-shelf to customers because it is absolutely safe unless something is wrong with the factory ECU or boost controls.
A custom tune can find additional power in most cases because there are car to car variances in the mechanical parts such as the turbo, the flow rate of individual injectors, perhaps the static compression ratio in the cylinders, the intake manifold and cylinder port castings, etc.
Also, in the northeast Pruven Performance has an AWD chassis dyno and Shiv has made at least two trips out there to custom tune cars.
EDIT: That's cars, not just one car.
Wingless Wonder is offline
Old 11-11-2003, 06:22 PM
Jimbo's Avatar
I had my car dyno'd at the ATP dyno day with a Cobb Stage II reflash. As mentioned above, conditions were abysmal with ambient temps of 90+ by 10AM. My car pinged one time on the first pull, compensated and still managed 216.8HP and 214.2FT-LB on the third and final pull - not bad considering the conditions. This was with Scoobysport DP/MPs, Prodrive axleback, Samco IC hoses and yanked intake resonator (Stock uppipe and crap 91 octane)
To get back on-topic, I would recommend Cobb for your situation for a few reasons:
1) You are not located near either Vishnu or Cobb, so no advantage there (i.e. dyno tune)
2) You do not plan to go past Stage II, so off-the-shelf map will work fine. Cobb's reflash is significantly cheaper than ECUtek and there is very little difference in their off-the-shelf Stage II maps from what I can tell. Hence the reason I have Cobb.
As others have mentioned, you do NOT need a boost controller with a reflash. It would actually defeat the purpose of paying for all of the safety features of a reflash. I would also recommend staying with the stock intake and stock BOV for Stage II. I came from the Honda world as well, but things are different here. CAIs are well known to cause lean conditions and CELs on WRXs (MAF is very sensitive) without proper dyno tuning and the gains are minimal unless you're making big power. BOV is your call if you like the noise, just make sure you buy the right kind as many of the used ones up for grabs are usually the wrong kind.
Jimbo
Jimbo is offline
Old 11-12-2003, 03:51 AM
McBain's Avatar
Car Info: WRX Shooting Brake
KTR Performance in Ayer, MA, is getting into the Ecutek reflash business. I just got a custom reflash from them and I'm pretty pleased with it. The car is quite badass feeling with more ***** to the power. I got 22 extra hp the first time, and that was very conservative due to the limits of the VF24 with stock injectors. After STi injectors were installed I got another 35hp. The guy who does the reflashes, Guy, know his stuff, and is keen on demonstrating how he does it They've also installed all my parts.
A bonus for the place is that there are some goddamn sick cars there for drooling on, like a Ferrari 250 and a 288 GTO, lots of Porsche Turbos, some Maseratis, Alfas, etc. Their sister operation, KTR Motorsports, restores, maintains, and stores these cars.
They are having a Subaru dyno day and Ecutek demonstration on Nov. 22nd: http://www.ktrperformance.com/galler...u_day_1103.htm
McBain is offline
Old 11-12-2003, 09:00 AM
DJ Catchem's Avatar
Car Info: '02 WRX sedan
Thanks for the replies on this. McBain, thanks for the link on the Dyno day...I'd love to see where i stand.
Thanks for all the suggestions here. I appreciate it. What are the thoughts on an upgrade path starting here? Is it recommended to start with the re-flash, and then go at the exaust? I'm trying to do this in steps due to financial reasons, and the re-flash seems the logical starting point.
DJ Catchem is offline
Old 11-13-2003, 09:21 AM
samagon's Avatar
my friend sent me this, it is not out yet, but it is basically a reflash for the ecu that isn't a reflash, it gives you total control, and it is from cobb.
maybe next summer for me
http://www.wrxforum.com/cgi-bin/ulti...1;t=000017;p=1
samagon is offline
Old 11-13-2003, 04:07 PM
Origami posted by Ender2664
Is it better to get the reflash or use the turbo xs piggy back system?
Turbo XS uses the UTEC. It allows full user tuning of the ECU, which a lot of people like. Some reflashes allow some degree of user tuning but not as extensive as the UTEC. The reflashes are pretty much trouble-free, though, since they rely on a professional tuner to make the tuning map. Probably depends on your preferences and whether you plan on making incremental changes over time or doing most mods within the next few months and then you're done. The UTEC and XEDE can handle a lot of different mods (although I've never tuned a car myself) so the initial cost may be higher but cost-effective in the long term.
Quick Reply: Vishnu vs. Cobb reflash?
