Vishnu Stage 2 questions
Origami posted by Twenty36_1
I got a fast response from Vishnu, they also said check for Valet mode and told me how to do it. They also recommended to check for boost leaks.
Any ideas on common places for boost leaks? This is my first turbo car so I have no idea where to start, other than the intercooler connectors.
Check the vacuum hoses that make up the factory boost control, posted courtesy of RussB. If you have a boost gauge, check that vacuum hose, also. Check other vacuum lines while you're at it. It only takes a small split in the hose to mess things up. Some cheap vacuum lines may have a seam that runs along its length - that's a common place for a split to occur.
Originally Posted by Twenty36_1
Sure no problem, do you go out the KK meets? I may go on Tuesday if I leave my martial arts on time. First gear pulls mean as heck, but 2nd and 3rd is a little weak IMO, but maybe I am used to FWD where time is made up later in the 1/4.
Cool, check to see if it's on valet mode. I forgot how to. But post back up if you figure out if that was the problem!
I tried the reset just a minute ago, but it did not work (or I could have done it wrong. It is just TURN KEY TO "ON", PUSH GAS PEDAL TO FLOOR, and HIT REAR DEFROST, right?). Tomorrow I will check the hoses.
It toggles the valet mode immediately when I've done it. I've toggled the mode both with the engine off (ignition on), and also while driving. Works the same whether engine is running or not.
I figure I will post this so if anyone searches they can find info that helps. I went to Vishnu yesterday and had Shiv look at it. He said that the stock wastegate actuator setting is set to 11psi. he tuned the car and it reaches 17psi now peak and 15psi holds. I also found out that my turbo is NOT a VF34. My turbo makes peak trq. lower and it makes fewer peak HP. Now to find out what the hell turbo I have.
I made peak 235WHP (well 234. something) and I forgot the peak TRQ. No baseline was done so I have no idea how much I gained. BUT probably like 40hp or so.
If some one has a floppy drive on there comp I can give you the disc and post dyno plots (sorry my comp only has CD drives)
KTW
07-12-2004 08:33 PM
David@VISHNU
12-10-2002 08:40 PM
