Vishnu signature series DP
Car Info: 02 PSM WRX
I was wondering what you guys thought of the Vishnu signature series DP. I like the way the wastegate gasses merge with the exhaust so far down stream but it seems like if you had a big turbo and some massive power the way they meet would cause a lot of turbulents since the wastegate pipe comes into the exhaust at 90 degrees. I would have thought it would have been a lot smoother with a 45 or 22 degree merge (more like the other Vishnu DP). Vishnu's other DP (the one that doesnt include the midpipe) tapers down before the midpipe but I dont know what diamiter it starts at or what it tapers to. I dont know how important the angle at which the 2 merge is since it is so far down stream and I also dont know how the taper in the other DP would affect flow so I was hopeing someone here could give me some schoolin on the subject. I am thinking there is nothing wrong with the design of either of these DP's since it was designed by Shiv and we all know that he knows what he is doing.
Vishnu DP http://www.vishnutuning.com/images/p...20Downpipe.jpg
Vishnu signature series DP http://www.vishnutuning.com/images/p...lose%20up2.jpg
Thanks.
Thanks.
I would go and ask Vishnu in their forum. I would expect them to say that it's definitely better to run the complete turboback exhaust, rather than just the downpipe. The stand-alone DP is intended for customers who simply do not want to replace all of their catalytic converters. It is a good design, but doesn't make as much power as a full turboback can. It's best not to mix-and-match components.
CupertinoSteve
01-07-2004 02:33 AM
