vf34 wastegate
Old 09-11-2008 | 06:58 PM
freshrex's Avatar
Car Info: white 03 wrx
vf34 wastegate
so i have a jdm vf34 spec c turbo running at 18-20 psi on my wrx. the wastegate seems to leak at that much psi so i started looking at the Forge Wastegate (stock location) but they say it only works for the vf34 "gdb" not spec c... is there any way to just tighten the spring or something on the 34's stock wastegate??
Old 09-13-2008 | 02:46 PM
wrxisthebest's Avatar
call Paul@ Dbtuned.. he will help u answer ur question..
(916) 791-4900
Old 09-13-2008 | 03:16 PM
VRT MBasile's Avatar
Paul@DBtuned although he's kind of far from San Jose.
Your other options are:
GST
SpeedElement
LIC
Old 09-13-2008 | 03:42 PM
03_Impreza_Al's Avatar
So you are experiencing boost creep?
Old 09-13-2008 | 06:13 PM
xhengmanx's Avatar
dont forget about kevin at autohq. he knows alot about jdm parts.
Old 09-13-2008 | 07:01 PM
freshrex's Avatar
not boost creep, more like boost leak, if i accelerate from cruising, all my boost flutters out, if i am going wot from a stop, it doesnt leak, so basically when im "bogging" or not in a low enough gear, i think i can hear my wastegate fluttering and letting all my boost out...
Old 09-13-2008 | 07:15 PM
Has your car been pro tuned or are you running an off the shelf map?
Old 09-15-2008 | 10:09 PM
i have a spring on my turbo actuator arm
the VF34 wg is garbage !
Old 09-15-2008 | 10:31 PM
strider327's Avatar
Car Info: 2005 WRX
Time to go external wastegate! Might as well, its a better setup overall.
Old 09-15-2008 | 10:37 PM
thats what i was thinking^^^
Old 09-16-2008 | 09:22 PM
freshrex's Avatar
i think the sound/loudness of an EWG would take away from the clean beautiful burble of my completely catless vf34 wrx... is there any way to tighten the stock wastegate actuator arm or change the spring or something??
Old 09-16-2008 | 09:27 PM
freshrex's Avatar
minibump
Old 09-17-2008 | 12:11 AM
Have the WG ported.
Old 09-17-2008 | 07:55 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
What type of engine management are you using?
Old 09-19-2008 | 12:47 AM
freshrex's Avatar
protuned by eip thru a cobb ap
Quick Reply: vf34 wastegate
Top
