VF34 Set up on stock ECU?
Car Info: 02 PSM WLX
I have a vf34 set up: pinks,walbro,bigger tmic,dp,up,etc..
My cobb ap will be coming in in about 2 weeks, in the meantime is it safe to drive my car on a stock ecu (02)? I would like to drive it from SF to So Cal, any precautions?
Car Info: Stage 4+ Bugeye
Well if you haven't driven it around town and already realized, it idles like poop, and if you try to boost at all, it will fall on its face. Which could be a rather dangerous thing if you are trying to pass a truck on the 5. Plus there could be engine problems, since it is running so rich, it could foul your plugs, and that would mean you would have to replace them, which is not that bad but they are hard to get to.
Cheers,
Austin
Cheers,
Austin
Originally Posted by chocolate
Ah, I see. I havent driven it yet as it is still at MPJ. Thanks for the warning, I will wait on the driving until EM. Btw, were you ever on the HT/ITR forums?
By the way driveability might not be as bad as I previously stated, I had P.E. 800cc injectors that had to be tuned down, so my idle was really bad, but with pinks it shouldn't be too bad.
Austin
FostersAFB
09-08-2004 04:04 PM
fireguyrick
14
01-11-2004 10:23 PM
RussB
11-22-2003 08:21 PM
